Drivers Side window kepts dropping on its own???
DannyH
Hi all,
I am currently having problems with my central locking, my passanger door sometimes wont lock or unlock, dont know what it is so if anyone knows please help, anyway, today i went to the gym and when i returned my drivers window was down, i thought i had just left it open but i went to my parents and when i came out of the house the same thing had happened, so please help me with any ideas you may have to my problems,
Can you believe ive only had the car 3 days, i would take it back to the garage i brought it but there 200 miles away so if its something i cant change or fix with your help id rather do that.
Thanks so much
Danny
The car may be set up so that you need to press unlock twice for the passenger side to unlock, one press will only unlock the drivers side.
With your opening window, if you hold down the open button (say while the key is in your pocket) the windows will open.
Give them both a try.
Hi Mike,
Thanks for the help, i know that the car isnt sent up to press the button twice to open the passenger door as it also does it with the lock and open button inside the car, as for the window ill see if the hold the open button thing works and see what happens, thanks again for your help, i really just want it all fixed, just need to find out the problem now.
DannyH said:
Hi Mike,
No. Mike's right. The fact that you need to hit the center console unlock button twice to unlock the passenger door confirms your car is set-up the way Mike described. You need to get your keys re-programmed (bring all keys with you to the dealer).
