Hello all,
I did search and I cant see anything online for this. I replaced my drivers side window cable and to test the motor I connected the battery with the airbag disconnected (I realise now it was a bad move). Anyway, sorted everything out, however, I have the airbag light on. I know I need to reset the code, so i tried a friends odb2 reader to clear it and it didn't move. I've been meaning to buy a good reader for a while so I thought I would invest and got an Autel MD808 Pro, but again it won't clear. My question is, is this mostlikly the airbag that needs replacing or is there anything else it could be? The light was not on before and I dont know if there is anyway to test to see if it is the airbag or a sensor etc. Also can they be damaged this easy? Also I have checked and it is plugged in, I just don't want to buy another and be in the same situation. Any help will be appreciated. Thanks.
. So I cleaned the connects under the A pillar as I didn't think of this before so thanks, but this didn't help. I though sod it and got a replacement airbag off flebay, again no luck. I saw a video online to test an airbag as the should have around 2-3 Ohm resistance. I disconnected the door connecter and tested continuity to that and the airbag connector. When I knew I had the correct wires in the connector, I then connected the air bag and tested the resistance. I read 2.1, disconnect the new one and tested the old and this was the same 2.1/2.2. This seems to be in the ball park for a working airbag so I think this is something else. This also means everything is good from the door side of things, so not sure where to look next.
