Driver side window annoying squeaky sound
Dfdez
Hey guys, maybe someone could help me out with this I live in miami and the heat is horrible, my driver side window squeaks horrible during the day, but at night its normal...any ideas?
Anything would help.
I was once told to put talcum powder along the rubber edge and glass to 'lubricate' squeeky windows. Never tried it so can't confirm whether it works or not, but only concern is would the talc clog up winder motors? Anyway in sure someone more tech minded will be along soon :)
Got the same problem.
Even I live in "cold" Finland my car does the same thing in hot summer days, especially when the sun heats up the window. HELP NEEDED.
Mine did something similar - dealer took door apart & just needs new internal seals, around £70 plus fitting per door
z4alfie said:
Mine did this for a while then the regulator failed. Beware big bill looming
Big bill might be a little over the top! if it goes then it's ~ 130GBP for the part and 2hrs DIY first time round and fairly easy. probably 1 - 1.5 hrs if you take it to a garage.
as the OP's is fine at night and in miami it is probably the heat softening the rubber seal. cn ou identify the source of the sound?
as for a solution .....cant offer one... sorry.
I have owned 2 Z4 coupes (build dates Jan and July 2007), and have had the same problem on both.
The first Z4 had the squeak from brand new ... if you open the windows slightly whilst driving, the squeak goes away.
I contacted BMW Sydney about the issue ... they advised me to get some silicon lubricant spray, and dab a little onto the black rubber seals on the door frame ... i.e onto the rubber seals that the window closes against when you close the door. When you apply it, make sure to leave the window half open, so that when you close the car door, the window does not touch the rubber seal, so it can dry for a few hours before you raise the windows ... otherwise the silicon lubricant gets onto the windows, and it leaves awful streak marks which are difficult to remove.
Oddly enough, the Z4 Owner's Handbook specifically advises one NOT to use silicon spray ... but I tried it, and it worked ... for a while ... and then the noise comes back and one has to put some more on.
The second Z4 coupe also has the noise ... when you go over bumps or brake ... and the noise also seems to stop when the window is left a couple of cm open .... I've tried the silicon spray again ... no luck so far on this car. (Only recently got the car, so haven't looked into this properly). If it doesn't work, I'll have to ask BMW to change the door seals.
like z4alfie, mine did this for a short while then the regulator cable snapped. think it was £120 for the part and fitted myself (picked the wettest weekend in history to do it and ended up going to an under-cover carpark to complete the job!)
