Hi all.
I have had an on going issue with wind noise coming through my window following the replacement of a window regulator a couple of months ago.
Having adjusted just about everything I could with the window, I have come to the conclusion it is the rubber seals that need adjusting, not the pitch of the window.
I priced up a set of replacement rubbers which was £170, so I parked that idea for now.
I have taken the seals off and replaced them, however the more I do this, the more the fit seems harder to get right.
Can anyone recommend a way to easily put the seals back in place, as it is very difficult to actually get them to sit perfectly flush with each other?
I'm sure this will fix my problem, however I am loathe to spend that much on new rubber seals and not be able to get them to sit properly. I will try with my existing ones first though.
