Driver side door problem
a17dre
New member
I own a 03 plate BMW 2.5l Z4, which I bought around 9 months ago, and am having problems with the driver side door mechanism. Recently the door does not open from the outside, even though the doors are not locked. I can currently open it from the inside if I reach in from the passenger side door, which is far from convenient. This has happened once before, but the problem even escalated to it not even opening from the inside and I had to climb in from the passenger side!
Last time the problem seemed to fix itself, as the morning I was taking it to my mechanic, the door miraculously worked fine even though it hadn't for the past few days. I took it to my mechanic anyway and they told me it was because I do not drive it enough and the battery in the key had lost its charge. I've tried driving more, but it didn't make a difference. Is this right and does it happen often? Any ideas on how I can fix this?
Hi and welcome to the forum!
I had exactly the same problem with the co-driver side door. When i took the car to the dealer it was diagnosed with a faulty door lock mechanism and a broken metal cable which connects the exterior door handle with the locking mechanism.
I hope this helps.
Good luck
Hi, cheers, wish my 1st post wasn't about a problem though! :)
Thanks for the advice, will book it in with my local dealer asap...
