Drive Shaft Differential
Angelus666
 Essex
So, found out that my drive shaft diff was leaking from the visit to Bristol BMW during the Welsh meet...having it replaced second week in July. Anyone else had a leaking diff and had it changed...? Also, found out that my screen washer system needs replacing too, as there was a small leak...so that is also being done.
New nickname for my car is Triggers Broom.
Diff leaks aren't uncommon
If it's leaking out of the driveshaft seal then that's the " easiest" job.. Still 2/3 hours to see it done..
The washers will probably be you headlight wash pipes or one of the jets in the bumper.. Bumper off to replace the various bits and bobs..
Have you had quote for the jobs?
Yeah, think the diff leaks seem to be common....just wondered whether a small leak has ever turned into anything other than that?
Having both bits done under AUC.
