extrablatt said:willgill said:According to Ocean BMW the last time the RFTs were replaced at Sytner (not by me) the TPS was calibrated.
I'm not sure if the e89's TPS is based on rotational reduction or internal pressure, either way it should have pinged up regardless, the tyres were totally flat.
Apart from the dealer calibration, were you also manually resetting the TPMS every time you fill your tyres? If not the tyres won't be set to the correct pressure.
Never touched the tyres aside from a visual inspection for tread, probably done less than 1000 miles since I bought the car certainly never added any air to them. I can't think of any car I've owned that I've had to constantly add air too, what are you doing to warrant that?
