Door Trim broken!
jamiez
SW London
Hi
My drivers side door trim covering (the shadow plastic chrome piece) has a clip broken on the bottom so is now loose.
Has this happened to anyone else?
Looking at the realoem site, it looks like it could be 15 quid!!!
Doubt i will be able to claim under warranty either...
Just seeing if it was common or not!
Jamie
Common and easy to break. Usually done by not refitting or removing it properly. Worht a go under warranty as if you have not tampered it shoufl not fall off
If it does not otherwise need replacing due to scratches then you can slide it up from the bottom with just a small dab of adhesive inside at the lower end to stop it sliding down.
I'd expect £30 a pair for those.
Thanks CJ - thats the thing, i havent touched it - yet it came away at the bottom.
Car is back in the dealers today to get a couple of warranty items done so advised them of that also - lets see what happens!
Jamie
