...or at least try not to worry about it too much, Andy!Lillywhite said:So the message is 'don't worry about it'. :wink:
Yes from a Murco garage,but when i had my e46 i always used a different one with no probs?srhutch said:Andy, do you use the same petrol in it every fill?
No symptoms at all other than the emission light coming on,had manifold replaced,two 02 sensors,software update done,smoke test for leaks,so indy told me as a process of elimination it has to be the cat,but there is no sulphur smell,no knocking or loss of powerZ4M-2006 said:Im not sure of the history of your fault,but sometimes the EML can take a few weeks to illuminate..
This is usually when fuel trim faults are present.
Cats are usually easy to determine if at fault..Let me know your symtoms and stuff and i will try and advise you.
