done polishing
kal
i just took my car to polish it, when can i use zaino ?!
and is wax same as polishing ?!
coz when i use zaino it's different than polishing i feel like zaino is giving me more gloss to the car !!
Here is what I do to get my Z4 ready using Zaino products:
Wash thoroughly with Dawn
Clay bar entire car
Wash again with Dawn
Zaino PC Fusion (using a Porter Cable) if you have loads of swirls/towel scratches. If not, skip Fusion
Zaino AIO (again using a Porter Cable)
Z5 Pro (very light application with ZFX accelerator)
Z2 Pro " "
Z5 Pro " "
Here is the Zaino link with a longer winded explanation: Zaino
I believe using a Porter Cable applies product more evenly on the car no matter what product is used. I wash using warm potassium softened water, a boar hair brush and dry my car using a high powered leaf blower. I use a waffle weave drying towel to finish the drying process.
On the other hand....
Just this weekend I did a more thorough job of removing some pesky towel scratches and other surface problems. (btw, these can occur using even the best towels.) I used the old fashioned (and very very effective) method of removing (knocking down) 99.85% of all the swirl and other scratch marks. I wet sanded (1500/2000 grit) a small area then used a series of aggressive to mild compound product starting with wool pads to polishing foam pads to achieve a mirror finish on my Sapphire Black finish. I used Meguiar products for this initial cutting going from aggressive to mild, 3M Protect-it Glaze topping off with P21S Carnauba Wax. I did this to prep for what will be a very competitive car show season. This process is usually on done once every few years (for me, at least). It takes loads of labor and technique and unless you are going to compete is only for the truly obsessed. On the other hand, one could always pay a professional car detail to do this work for them. It wouldn't be the same, however. There are loads of product out there to use, some good, some are junk. The bottom line is to use a proven product with a proven procedure/process. Either way it is very labor intensive. The rewards can, for some, achieve nirvana level.
Then there are windows to clean. :headbang: I'll leave that for another thread.
i don't want it that professional and i'm afraid to use a polisher machine coz i don't know how to do it right.
i have Z AIO all in 1 and Z 5 pro, do i have to clay bar the car ?!!
so can i put zaino after polishing ?!
Dude, use the Cleaner first to prep the paint and then the Polish and you'll be good to go.. :thumbsup:
Yes the Clay would be ideal to use at first but it's not for everyone that's skirmish that hasn't used it yet..
I can't say if the claybar made a visual difference on mine as I did the clay/zaino process all at once. However I surely felt the difference. The clay bar made the car silky smooth. That said it adds alot more time to the job. If you use the clay bar keep a clean set of newspaper, cardboard or something underneath where you are working the claybar over the car. Because if you drop it you throw it away.
