Do I have a problem guys?
Nick7602
 Redditch Worcestershire
Hi Guys
Msport 3.0i, auto box…….
When im slowing down there is quite a clunk like the the gear box is disengaging……however the car does need new brake discs and pads
Kind Regards
Nick
Has the auto box oil been changed? How many miles has the box done?
'Clunks' on slowing down are sometimes front suspension unloading /loading on a bush..
Can you 'feel' where the 'clunk' is coming from?
Hi Pete
Car has done 91k, it has a full BMW Service history, but not sure if the oil in the auto box has been changed, dampers, and all the top mounts, washers, spring platforms have been changed, along with the anti roll bars and bushes.
The shift into gear with the auto box is rather clunky, but put this down to it being mechanical shift?
I was thinking along the lines possibly of prop shaft?
Nick7602 said:
Hi Pete
Could be prop shaft..I’ve personally not heard of that as a cause / issue..
At 91k a nice ZF oil / filter pack would definitely be a good idea if the car is a keeper..
Hi Pete
Ok that sounds like the next step I think, I was going along thinking that the ZF autobox was filled for life, I didnt realise it can be serviced, so yes will definitely get that done
Cheers Pete
Nick
Nick7602 said:
Hi Pete
Cheers Pete
Nick
50k miles is what ZF recommends for their box…I’m sure BMW has a greater insight into ZF boxes than ZF :tumbleweed:
For sure it won’t hurt…
