Going to do my first DIY oil change (intermim) on the car this weekend. I have read the how to guide. Is the M very different re. the filter or the torque values? Any help appreciated as I am a mechanical idiot
Taz x said:i have never used a torque rench when doing an oil change, infact i can only ever recall using 1 when doing a cylinder head
never changed oil on a zed though
S54 engine on Z4M has a vertical sump plug. N52 engine on Z4 has horizontal (sideways) plug.EdButler said:A little tip for you which you may find helpful... As the sump plug is placed sideways, use a LARGE bowl to prevent spillage as it flies out at an alarming rate sideways.
