I'm looking ahead to getting my list of Winter projects and one of them will be changing the transmission fluid. There are no transmission issues and this is just preventitive maintenance. I know BMW say this is lifetime fluid but we all know their lifetime is the lifetime before you are pushed into buying another car.
So if anyone has done this on a manual please jump in:
Question: Have I correctly identified the gearbox on a 2009 23sdrive as a GS6-17BG ?
Question: Is the capacity is 1.3L?
Question: And should the specification should be MTF-LT2?
Method:
I'll be getting the car lifted level on a car lift so it will be easy to access and the car will be level. Thetransmission will already be warmed up. Refill plug opened up first to confirm it can be refilled after draining. Then drain the old fluid. Clean lower transmission hole area and replace the drain plug with a new one (M18x1.5) 45Nm tightening torque. Clean the area around the refill plug and then fill up with new fluid until it just starts to overflow (or should it just be 1.3L regardless?). Replace the refill plug with another M18x1.5 plug same torque.
Anyone see an error in my specs or methodolgy?
Regards
Mark
Method:
Regards
Mark
