H highstream Member Gothenburg Dec 8, 2010 #1 I need to "reset" my zed by disconnecting the battery, is there any diffrence if i disconnect the positive or negative connector?
T Taz Lifer Saddleworth Dec 8, 2010 #3 i would say it makes no difference at all, all you are doing is breaking a circuit, personally i would always disconnect the live side (positive) and i would not even disconnect the negative
S SGR1913 Member Dec 8, 2010 #4 Fairly sure it's the negative you need to disconnect, again can't remember why
C cj10jeeper Lifer Lichfield, England Dec 8, 2010 #5 The logic is always to disconnect the negative, side simply because a wayward spanner can earth to anything with interesting results..... That's also the terminal specified in the TIS
