Well i knew if i kept the Z4M roadster locked away in the garage looking pretty i was going to save money.
Today going to work the engines sounding rough as hell, rev counter needle jumping around all over the place. Exhaust was popping away whilst i tried to manually counter the spikes in throttle with my right foot.
The it happens 3 lights; eml, dsc (triangle yello caution thing with the arrow) and the yellow engine block all lit up.
The car went into some sort of limp mode and i struggled to get it back home 1.5 miles @ 5mph max (5.50 am). Every time i tried to accelerate the engine died and i had to dip the clutch to keep her from stalling.
Eventually managed it back to my drive way and immediately swapped for the wife's nissan micra for commute.
Anyways this evening i started the beemer and same again. Throttling up and down rev counter up and down some dodgy noises occurring from engine. I plugged the OBC reader to get the codes
Heres what shows;
P110D - unrecognised
P1417 - unrecognised
P0139 - O2 sensor Bank 1 sensor 2 ----------Changed less than 6 mths ago
P0159 - O2 sensor circuit 1 Bank sensor 2 Ow res -----------Changed about 8 mths ago
P1637 - Throttle valve position control deviation -----------Changed about 8 mths ago
I tried the usual this morning restarting electric waiting ten seconds , then off , restarting 10 seconds electric only then off. It didn't reset faults.
I reset the codes this evening ( out of warranty now) and managed to get the engine warmed up with loads of drama then after about 10 mins it settles out fine.....engine ticks over nicely when no foot on accelerator. No jumping in revs and only fault P110D when scanned.
Is it time to get her traded as on top of this brakes and pads are needing done all round?
It's getting way too expensive to be fun anymore
Heres what shows;
