I knew it was bad but having a proper look under the M reveals a sorry sorry sight, so much corrosion on the hubs, suspension arms, steering rack, bush housings etc, just all over, etc, this on a 39k mile 2006 car. A diff oil leak as well as, I ‘think’ just rocker cover oil leak. Engine is as sweet as you’ll hear, gearbox is excellent, much less notchy than my previous high owner car, so nothing expensive on the horizon hopefully. Good news is zero corrosion anywhere on the floor pans, or underside other than running gear. The plan is a full car strip down, engine and box out, subframes, the lot, all panels off to correct any corrosion on the bumper brackets, inner wings etc, although they should be fine hopefully. Then a concours rebuild. I have both wet vapour and dry soda blasting cabinets ready to go for my new business venture, so the M will be a donor for for photos of blasted parts for a website. I’ve never tackled anything this detailed before so I don’t know how it’ll end up, in my mind it’ll be as new but how well it’ll go...who knows...!
Planned :
New OEM bushes all round
KWV3 coil overs (bought)
AP 6 pot fronts (Bought 2nd hand) 4 pot new rears. Braided lines all round.
Vibratech engine mounts
RTAB limiters
Remus back boxes (Bought)
OEM CSL’s in hyper silver (Bought but needing a refurb) MPS4 tyres
Schrick fast road cams with DLC followers
Walnut blasting
New rod bearings
Vanos rebuild
New clutch
Planned :
RTAB limiters
Walnut blasting
New rod bearings
Vanos rebuild
New clutch
