Dension - Urgent Q (need to order asap_
SamUK
Happy New Year...
What model of Dension can i put in my Z4? (2005 alpina Lux)
Only need to steam music from a USB stick?
Also will i get the track names up on Sat Nav Screen?
Anyone know
Sam
Have you looked at the compatibility list?
http://www.dension.com/sites/default/files/car-compatibility/bmw_04_04_2014.pdf
Thanks..how do I know if I have business or professional navigation?
I have the lux pack..but crap speakers..
Does your Nav flip up from the dash? If so, it's the Pro version.
Business is integrated into the head unit.
one of these will work
Gateway 300 Gateway Pro BT (for bluetooth Phone)
Just not sure if txt will work..
someone must have one of these running in there Z4's?
looks like this will do: http://shop.dension.com/en/gateway-300
Text display function of the relevant iGateway, Gateway 300 , Gateway Lite / Lite BT product is not available for BMW in case of: Gateway Pro is not compatible if: 3. Japanese spec. BMW is not supported
a.) Becker manufactured head units (except 16:9 Navigation) a.) The head unit is manufactured by Becker (except 16:9 Navigation) 4. Must have phone button on the radio
b.) The head unit has phone preparation (phone button) b.) The radio has factory phone module, or disabling the phone function or R/T button on the steering wheel for Gateway Pro
c.) The head unit has factory phone module
I am deciding on the Dension 300 with the same head-unit. Please let us know how it works out. Cause I don't know if this is a Becker unit I am also considering XCarLinks new gadget:
http://www.xcarlink.co.uk/product.php?productid=74&cat=16&page=1
But I've heard Z4's don't have CD-Text enabled by default. So how would you enable it? I know with Dension you make a SW upgrade which enables car's CD-Text. But I don't know how would you do it with XCarLink.
The Dension is only £109 - personally i would get this over a Xcarlink..
I have tried there AVR with my Dension 500 - did not work well..
have the Dension 500 in my e60 - its good as i have 160GB of music on there...most anoying thing is it looses track of folders when you switch the car off... annoying as i have sorted my muisc using folders \ albums
Also considering a Intravee...Still reading up on it though - have not used one for many years.. its meant to be better - only problem is it uses ipods and i dont like ipods and dont have any playlists..
Discussing here: http://forum.bmw5.co.uk/topic/105668-intravee-or-dension/#entry1130655
CD text - will the cd player play mp3 cd's? as this is how i tested my e60 - mine did, if it did not i had to get this coded @ £60..
from Richard - about cd text
Any idea if cd text is enabled on the Z4's?
If made after September 2005, or it's been upgraded, yes.
Decided... i want a Intravee II :thumbsup:
http://www.toysinyourcar.com/acatalog/intravee.html
+ KC420i @ £40 second hand.
You might find Aquazi has a spare Alpine Unit if you PM him.
Only issue is some iPods fall asleep after use and won't switch back on. I modded my Alpine unit to rectify this issue. I have details if you want them.
will do thanks..also one on ebay for £40..still may find one cheaper maybe..
Intravee is expensive...@ £151!
will pm you when im ready - still about a month away..only picking up the car tonight.. :thumbsup:
eBay used or new you are looking at £200 all in. Seems to be the going rate.
Try m3cutters.co.uk if you're happy with used.
Picked up the car yesterday...seems it has a Intravee already..not sure how old though...maybe 4+..CD changers been removed..
Also Richard said you don't need txt enabled on the head unit..for the Intravee..this is only needed if you will be using mp3 cd's
