dension gateway lite bt
chris g
Blackpool
So - sent the zed in to get the dension fitted today - mostly good results ...
Blue tooth streams music well from device in pocket - good
When streaming - the device menu options work - very good
when streaming - the steering wheel buttons work - unexpected and very good - volume and track changing
Connected - works and charges - good
when you dial out the blue tooth works well - great
if you are streaming and the phone rings - you can answer via the dash buttons - good
Quality all sounds good
if you listen to the radio and the phone rings - you have to answer it on the phone and select hands free - - ok ... (call logged with dension - any one else heard of that ?)
the fitter left 2 marks on my alloy dash - not so good - i paid for them to do it so that i didn't do that ... only small in time i may learn not to notice - pin pricks really ....
so far - £200 supply and fit with the iphone cable seems a decent spend - im happy, will attach a memory stick at some point and see how that works out
