Dension Gateway 100 ipod/iphone adaptor
itguy
Melton Mowbray, Leics
Hi everyone
Now that I've fitted my parrot mki9100 which has an iPod/iphone lead with it, I don't need my Dension Gateway 100 any more.
Now, the iPod plug has seen a bit of 'adjustment' in as much as I've removed the two locking tabs (that clip into the iPod to stop the cable falling out) and its been glued and then removed from a home-made ashtray mount. All works perfectly, just isn't that pretty. Fine for glovebox/cubby use.
Denison also sell new cables if you wanted a perfect one.
There is also an extension cable included for the Denison to iPod cable, so if you wanted to run it anywhere in the cabin (ie down the tunnel) you can.
I had this installed in my z4 which has the carver DSP full Monty sound system and it used the amp, subs etc. Appeared as a CD changer on the head unit, instructions on use are on the link here (or in the support section) http://www.dension.com/product/ipod-car-adapter/ipod-iphone-auxin-id3/gateway-100
Install is straight forward, no splicing of cables etc, all plug and play. Just take the centre vents out, then the stereo head unit and the large plug at the back comes out, plugs into the Dension cable, which then in-turn plugs into the stereo again. You do need to swap another couple of connectors over too, but all plug and play.
No idea how much its worth, say £65 by PayPal gift or bank transfer?
Can take pics if needed
Will
Too much then?
These seem to be about £120 new on eBay at the moment.
Say £55 delivered?
