I've had this problem since I bought my Z4MR a year ago.
Especially if its cold (and wet like this morning), I have the fans blowing slightly outward (toward me) on a cold temperature whilst driving. Then this morning the screen started to mist up. In every case where this happens, if I put demist on, it starts to blow the screen with hot air and only clears a tiny section on each side low down and DOES NOT clear the entire screen. This is in contrast to another Z4 I've been in where demist clears the screen in 4-5 seconds!! Trying demist on a different temperature makes no difference (of course).
Also, if I'm generally driving and have some air blowing on the screen (set to blow up rather than outward toward me), it seems to mist the screen up rather than prevent it from misting.
If I put demist on and feel by the screen, it is blowing air hard from both sides. I had to stop this morning and run the screen down which you don't expect to need to do when you've got a supposedly amazing demister!
Could this be a problem with the alignment of the fans behind the dash so they are not pointing up enough or something? Anyone else had a similar problem?
