I'm planning a stereo replacement in my Z4M e86 which would include installation of a DAB antenna. Most commonly these are small units which stick to the windscreen like this. I was after some opinions because there are 2 things I dont like about this.
1. I'm unsure how permanent sticking something to the windscreen would be. If I wanted to remove it at a later date how hard would that be?
2. I dont like being able to see the antenna on the windscreen.
I understand general opinion is that the antenna cant go on a windscreen with a heating filament in the screen (like our rear window) as it would interfere with the signal. Would the interference only be when the heated rear screen is on? In which case it wouldnt matter as I mostly drive in the spring/summer so no interference or would there be interference when the heated screen was off too?
Is there some significance of the FRONT screen? I'm wondering if it would work if I installed it on the small side window just behind the passenger?
Any opinions or suggestions greatly appreciated.
