Dab Radio
Anyone know if there is a way to upgrade my radio with DAB, my car is 2010 and doesn't have it but I've noticed some later cars do.
It's a 3.0 with idrive.
I made an enquiry a couple of years ago with a car Hi-Fi specialist and was quoted around £1,000! Needless to say that I didn’t bother. I’m sure you could diy but I’ve had reasonable success just using a radio app on my phone, obviously this uses your data allowance and reception can cut out according to mobile phone signal.
For DAB integration into the BMW system you have a number of options
BMW solutions....
1) Replacement headunit with built-in DAB + associated antennas = Quite expensive.
2) OEM add-on DAB module + associated antennas = Cheaper but needs specialist coding, plus quite a bit of fitting as it's located in the boot.
Non-BMW solutions.... (and in no particular order)
3) FM transmitter box with separate control... https://www.ebay.co.uk/itm/264990080187?hash=item3db2a3bcbb:g:34EAAOSwyTJf5x5O
4) Dension Gateway bluetooth with add-on DAB = expensive and giving you extras you already have, found a used one here... https://www.ebay.co.uk/itm/165170384464?hash=item2674ec0e50:g:wyAAAOSwo8Rhhqd4
5) Mr12volt add-on box that plugs into the MOST fibre optic line, you must have CD Changer added to the VO list for this to work... https://www.ebay.co.uk/itm/124978208317?_trkparms=ispr%3D1&hash=item1d19481e3d:g:CAwAAOSwJrVhe8qJ&amdata=enc%3AAQAGAAACkPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSxXDXcCydCuSj2Tq2S%252F3GnpON8gDf0jtVVdaE4%252Faz6JLhCT2v133loA73F8EMytMxKr2gzxB0BCUHuZn%252FfzlXYUJ8LMkFiIIKG3OXJ1Bh8X583IIs0Sgimb9NAnXORNvCohOD01QLU8Gs07oD1LI8%252BW5pWY5uugA2ptFTmn%252FYBLFsjYGpLPieOlI%252BclF0W4n03rLnCb6dxnFzVee35bMCDjxmXMD7D26MMMFbQn6JI3i2zMu6rJeRAszxcZI0daA90Nnq8OShE0SDKLxY%252BUontjlfMV4iDvCpDhhTKK6w6b0Cv25rreJ8EhygbVR9oJoTECPpQHkjBlC3aa7Oyhk2%252FGjA3okhbzGMFxG87pPxs%252BxgU7vRZRM5%252FzEJIhh6A0e6W5sOQANKU%252FzeCcK0ThgK%252BuoYG0MiByA%252B0tzWXuYgOwmZh%252FW9duwpz4ji20csz8Uyuy5mUciO0NoiIlNPFQG%252BPk11rqabEphkM0%252BTDjEVB1lzPSkRVsuyQM%252Bn1F2p9rvSTUZTDu6ef4uauJH0ResXCq9cYrsZ2OLRThuReCww58hwQYIDwUEOZLI2YABUcFzV2%252BTKyr6I20pEDoIqQBMabvh5OXsYrv%252BFBWN%252FA4JFAhAkKKmXx2h2IdjlBuq6c1TzUHDNW7KsnzZgmszxOKyI%252FodY8COSoUgGiH%252BP7IhdpZejMKasWAqj1FwQlrmRQCzSglJwQ5KOj98EcEcGnzf9QwNlvPpX4vPO4aZMglv3oC3H8x7wGfwvtxjMMADk8z%252BkCDKKgtm1yz2cU0oGBgBMPHY0JJYLeQJjqY0z%252FVyJRW1RMeJ0%252FBsH6yGej3qHLKLh%7Cclp%3A2334524%7Ctkp%3ABFBMyrKtuKBf
6) Fistune add-on box, again into the MOST line so same as above... https://www.ebay.co.uk/itm/263957440375?hash=item3d7516e777:g:WkAAAOSw1Ndbqkuz
7) Autodab box, now this is exactly the same as what BMW offered as a dealer fit option. They do come up from time to time used... https://www.ebay.co.uk/itm/360557371399?hash=item53f2e4e007:g:k6YAAOSwnVZasW0X
8) Another Autodab product, this time it uses an app on your phone for control but not data usage... https://www.ebay.co.uk/itm/381494395017?hash=item58d2d68089:g:O9AAAOSwSdZWcr22
9) Another Autodab item, this time with a control and display screen... https://www.ebay.co.uk/itm/381987979302?hash=item58f0420026:g:wVoAAOSw4A5YuCQK
10) The final option is installing an MMI box into your iDrive system. This then connect with your phone to give you Apple CarPlay (for iPhones) or Android Auto (for Android phones). You then simply use one of the available radio apps for clear digital radio, this is dependent on phone signal, but then DAB is dependent on a digital radio signal. Obviously you get all of the benefits of the phone integration with this option for navigation and music as well.
Hope that helps :thumbsup:
Wow, AnubisZed, thank you very much for all this info. I really appreciate the time and effort you must have put in to get this information.
I've not had time to go through it yet but I will shortly, it looks like it'll be a bit more work than I had hoped for though.
