CSL alloy sources (or copies)
De4n said:
Here is a picture of the 27mm offset. I didn't drive the car just in case it damaged the wing, but as you can see from the picture the offset is just a little too aggresive
Are these original CSL's or the copies?
(not that it matters as both are listed as the same width and same offset so should fit exactly the same)
So who has CSL wheel on their Z4M? Can they confirm they have fitted 235x35x19 to the fronts and 265x30x19 to the rears.
These sizes sound right compared to the stock 18's, down 2 profile sizes as the wheel size has gone up an inch and the width has gone up 10mm.
They're the tyre sizes I have on mine yes
Looking at the Vredestein Ultrac Sessanta as they get good reviews and arent that expensive;
(mytyres.co.uk)
ULTRAC SESSANTA 265/30 ZR19 93Y XL £183
ULTRAC SESSANTA 235/35 ZR19 91Y XL £157
I assume you can have different load ratings for the fronts compared to rears? :?
IIRC the stock 18" Conti's are 91Y?
