cruise control retrofit - program/encode???
seanodwyer
 Wexford
Hi,
Just reading the instructions for a cruise control retrofit on a 05 2.0. at the end they say:
"This retrofit system requires coding. - Program/encode the retrofit with ISSS (integrated software service station via the - retrofit/CIP path."
Ahhhh! Does this mean it needs to be installed by a dealer?
Sean
Standard stuff they add. The same they said from the SatNav retrofits as well, quite expensive coding work as well.
None required - you will be all good (assuming you have added the cables required ...)
I'm with the other guys here, when I did mine a few months ago no coding needed.
Best value for money you can do IMO.
I did a retrofit guide a while ago on the forum with pics and explanations. Search for that, not sure quite where it is but it will help you. :)
That'll be this one then......
http://www.z4-forum.com/forum/viewtopic.php?f=34&t=19242&p=279688&hilit=cruise#p279688 :thumbsup:
