AndyMitton
I know there's loads of stuff on this on about here and there but just kind of want some reassurance:
Basically my car is drinking a fair bit of oil (I know they do and the limits they spec). I'd say maybe a litre every 600 miles ish
There is also what appears to be a small leak of oil near the CCV area (at the front of the engine bay on the intake side).
Got a small amount of vacuum at idle on the crank case and on the dipstick. Think I might try the water in a tube method but won't have time before the weekend and was thinking of doing this at the weekend if needed.
Also when I switch the engine off there's a rather loud sucking/gargling sound coming from around the dipstick
And when I changed the plugs a while ago there was a small amount of oil around the spark plug threads...not below...cam cover gasket maybe?
Anyway any thoughts on this would be much appreciated.
If needs be, thinking of buying the separator and hoses and cam cover gasket and changing over at the weekend
Thanks in advance
Andy
Thanks in advance
Andy
