I'm after any advice at all please as I find this rather worrying.
I recently took the 2006 Z4M to RBM for an oil service and to investigate some error codes. They found some vanos faults such as vanos intake and exhaust measurement checks were not in spec. They cleared the codes and after a test drive the codes didnt come back. They advised if the codes came back it might need a vanos rebuild with someone like MrVanos. The errors have since come back (vanos and camshaft errors). RBM also advised that they thought there was a slow oil leak and to check the CPV (Constant Pressure Valve). I dont see any oil under the car so it must be an extremely slow leak.
I found https://www.zroadster.net/forum/viewtopic.php?t=31401
and the opening poster there explains about the CPV "It's purpose is to ensure that oil stays at the top of the engine, thus ensuring the vanos, camshaft and tappets are lubricated at start-up." He explains in the attached youtube video that a CPV leak can cause the vanos to fail.
So I am now wondering if the CPV started leaking and this has now damaged the vanos. I was going to call MrVanos today to get a refurb but I am now thinking that if the CPV is leaking and that caused the vanos failure then I need to fix the leak first or it could just damage the replacement vanos? Does that sound sensible?
I have ordered a replacement o-ring for the CPV from https://www.hackengineering.co.uk/product/s50s54-viton-cpv-seal/
Has anyone replaced their CPV? I have found some M3 videos which show the replacement but I don't know if the CPV placement would be the same in my Z4M.
I'm also a bit nervous about getting under a car on jack stands. Should I look for somewhere that rents out a garage with full-on post jacks to lift the car or a maintenance pit?
