Coupe boot lock
fd3chris
Liverpool
Hi guys had a weird situation happen today. I was in the middle of doing a window regulator rebuild and had shut the boot. When I went to reconnect the battery I could not open the boot with the key in the lock, it wouldn't turn in either direction. Any ideas apart from the obvious, barrel must of been changed before my ownership? Thanks.
If you have another battery you could try connecting it to the jump start terminals under the bonnet with jump leads then use the boot release button by the door jamb.
I hope you get it sorted. :thumbsup:
Thanks. I did actually solve the problem, I leant over the seats, hooked the positive cable quarter on with a crowbar and then held the negative against the terminal with the bar and got my gf to pop the boot open as normal. I'm still wondering why my key does not turn the lock in the boot. Either it's broken or it's a different barrel I guess.
Glad you solved it. :thumbsup:
From what you've said it sounds like the lock must be broken, or the barrel has been changed.
I've never used either of my keys in anything other than the ignition - I think I may try them now! :)
