Correct way to remove these..?
RickZ4
West Dorset
Simple when you know how, but I don't want to damage these plastic fasteners which secure the lining of the hard top.
Do the centre pins have a spiral thread? If so, do they come out all the way?
Hi
Yes they do have a screw thread to them, if you get a Philips head screwdriver and unscrew, the centre will come out then the outer will just pull out of the liner.
If the centre just spins as you turn it then slide something flat under the head of the screw and apply a bit of lateral pressure as you turn it and that should help draw it out.
Stuart
Stuartt said:
Hi
Stuart
Thanks :thumbsup:
For those fasteners that don't remove with a screwdriver get one of these at any auto parts store...
