Had a issue with my roof which some others on here have same symptoms. Roof won't retract but closes ok. You can hear the motor spinning but need to help the roof back by hand.
Issue was prior to relocating motor to boot, 1. replaced motor only but no different,
2.swapped hydraulic lines over other week and it worked for all of a few goes.
3. So ended up buying a replacement pump & motor, Worked first time and pulls roof down and it also locks in place. Cycled it a few times and topped hydraulic fluid up.
Issue was a faulty pump not motor.
