So,
Recently I encountered a couple issues when trying to use the soft top. Retracting it for maximum-sun mode is no issue, and it almost seems to retract more forcefully and quickly than before. However, when I attempt to raise it back up, I hear the motor function, but the roof fails to rise. In addition to this the emergency release does not function at all (I've used this once before and have a feel for how it should be working).
I was able to get the roof back up instead by having one person hold the close button, while I lifted/pushed the roof back into place. When the roof was about 3/4 of the way closed, the hydraulics seemed to kick in again. When this happened, the roof closed with greater force than normal. Does this sound like a hydraulic line is getting pinched, and at a certain point is being subjected to enough pressure to overcome that pinching (thus the slamming of the roof, and the rapid opening)?
I'm in the process of relocating the roof motor to the boot of the car ('06 3.0si), as I initially figured the roof motor woes had finally hit me. So far I've failed to remove the motor from BMW's interesting choice of location, however the motor does not seem to be the original, has a mostly full hydraulic fluid reservoir, and is missing its original sound dampening material (presumably got soaked with the original motor). I can't see the connection of the emergency release line to the motor yet.
Any ideas or recommendations?
