Nelly Welly
I have done the control arms on my E46 and am intending doing the Z next weekend.
I will do pics and a write up if it's wanted.
terry&jane said:Machine monkey said:Good stuff I have done the lollipop bushes arbs and drop links. I have the control arms and track rod ends on order. I hope they finally fix my handling woes!!!
As Bing says £50 is a good price![]()
It absolutely transformed the handling, I actually thought of selling the Zed it was so bad![]()
k31ron said:terry&jane said:Machine monkey said:Good stuff I have done the lollipop bushes arbs and drop links. I have the control arms and track rod ends on order. I hope they finally fix my handling woes!!!
can you describe how it changed? or how to check if its needed? I'm not happy with my steering currently changing from RFT's and getting wheel alignment helped, but it still seems a bit "all over the place" i.e its a bit vague, needs constant correction and still tramlines (not as bad after ditching the RFT)
k31ron said:The symptoms you all describe all sound so much like what i'm experiencing (its almost like the front wheels are a bit loose) so ordered the set from ebay ... looks straight forward to fit (although undoubtedly will be a PITA with corroded bolts etc), but anyone seen a "how to "? any special tips or gotcha's?
