Contisport Contact 5 tyre
paddy wright
Elite
 south yorkshire
Came on the alloy when I replaced one of mine that had a crack. Tyre is perfect and has around 6 mm tread- 255/35 r 18. (Rear off an ellipsoid- will fit 108s as well)
£55 posted.£40 collected in Sheffield area.
Couple of observations, it's more like 5mm and it's specifically designed for Mercedes cars as denoted by the MO marking. With the edge wear on top it's barely worth mounting. If you want to go drifting however... :evil:
Thanks for your helpful comments- there is no real edge wear beyond what you would expect with a part worn tyre- and the tyre came off a 107 so obviously will fit a z.
Not trying to dupe anyone- just trying to sell a tyre.
The MO just means it is approved by Mercedes. It's a tyre, it's not going to fall off if it's fitted to a non Mercedes alloy.
