Hi all,
I am selling a Z4 compatible connects 2 adaptor that I have just removed from my Z4 (I prefer to have the CD changer option as I can control it from the head unit). The Connect2 uses the same plug that the CD changer uses so you will lose the changer functionality with this installed. Prior to removing from my car this had been used with an ipod and it worked perfectly. The unit itself does have small installation marks on it, but obviously this doesn't matter when it is tucked away behind the dash!
This is a picture of the actual unit
This is simple to install and is designed to plug straight into the existing Z4 loom via the original connector blocks. The cheapest I have seen these for on the interweb is £60 (not including delivery) and one was advertised on here a couple of weeks ago for £45.
I am looking for £35 including delivery.
