AnubisZed said:On the replacement battery, you can get clone fobs with replaceable batteries.
pesticidal said:AnubisZed said:On the replacement battery, you can get clone fobs with replaceable batteries.
From BMW only, or aftermarket?
Any 2032 battery will suffice…![]()
Smartbear said:pesticidal said:AnubisZed said:On the replacement battery, you can get clone fobs with replaceable batteries.
Let me rephrase. Are fobs only available from BMW, or are there 3rd party manufacturers that have fobs that are compatible?
I doubt that BMW would be selling cloned fobs?
So your car does not have a hole for the key in the dashboard then!!!!Pondrew said:mcbutler said:Do you have two key fobs ?
Their is a procedure for resynching the key with your car, usually used when comfort access works but key fob buttons do not, but worth a try if you like, it goes like this.
1. Insert the key into the 'key hole' on the dashboard
2. Start the car and wait around a minute
3. Remove the key
4. Cross your fingers and toes (not mandatory)
5. Try your comfort access.
Anyone with comfort access should do this fairly regularly. Over time the key-car link breaks down and you can get to the stage where your fob battery is low but the car will not report it and your key could get locked in the car...
Comfort access doesn't have a 'keyhole', though. It is keyless go. The fobs have proper batteries which need to be replaced when they wear out. The OP said he has already changed the battery.
The one with comfort access doesn't, no. But that's not the Z4. I was presuming (wrongly) that all BMs with comfort access were the same. Turns out the Z4 has 'semi-comfort access'.mcbutler said:So your car does not have a hole for the key in the dashboard then!!!!
AnubisZed said:If you're not able to start without inserting it then I'd suggest one of the following....
1) Someone has changed to a non-Comfort Access fob!
2) Someone has changed the door handles.
3) Your Comfort Access is faulty - CA module gone wrong, receiver not picking up signal, etc
Could ve a good idea to have any fault codes read before doing anything else.
I would like to do that with my local dealer.....pesticidal said:and drove over the the local BMW dealer.
pesticidal said:OK. Got the new fob, and was online this morning with Bimmer tech to code the fob to the car. The tech guy said everything went well, and told me the original key was activated and should work, too. But the CA still does not work. Neither the doors not the keyless start. He said there must be something wrong with something else in the system, and said to troubleshoot the antenna. I've done some searching, but cannot find out much info on how to do this. I've found other threads with systems other than the E89, but nothing specific for my model.
Can anyone help direct me to something helpful? TIA
