mattstav said:I really struggled to squeeze my smarttop in, great bit of kit though, you won't be disappointed with it.
you can disable it via the indicator stick if you can't wait until after your MOT (not that it would be a reason for failure?) or just leave the cable plugged into the module protuding from the trim in the boot so you can plug it to your laptop without tearing the trim apart.
Stark said:Not an option unless you have keyless comfort access.
AndyJ said:Stark said:Not an option unless you have keyless comfort access.
Hi. I have the keyless comfort entry fitted to my car. Are you saying that I can close the roof remotely by holding down the lock button ?
Thanks.
Stark said:For comfort access you only have to press and hold the close button, the option you're talking about is with the smart roof and you code it with the clicks etc
AndyJ said:Stark said:For comfort access you only have to press and hold the close button, the option you're talking about is with the smart roof and you code it with the clicks etc
I'm probably confused. The original question was
"How can we code the roof to close while pressing the lock button?"
On my previous Z4 (60 35i) you couldn't close the roof via the remote, only open it. I've no idea what "smart roof" is.
Angie4m said:It's SmartTop which is a module that can be fitted to give some of the features of the comfort access as well as others like folding mirrors and one touch roof opening and closing.
Stark said:Andy remember you can open and close your roof with your key, just hold the open part to open the roof and the close part on the key to close the roof. Just keep it pressed down during the entire operation
