Ah
Eventuri...
As Argenta says, it will probably have an oiled cone filter..I think they used pipercross ( I maybe wrong there), the oil used to trap debri gets pulled into the inlet and coats the hot wire in the MAF with a residue coating... The DME then receives confusing info from the MAF and will pop a code over time..
Remove MAF and clean with alcohol or electrical cleaner... Let dry and see how you go..
If it happens again junk the eventuri and go back to normal air filter box
Eventuri...
