COBB AccessPORT 35i/35iS Engine ECU Tuning
Zikim
This COBB AccessPORT is a hand held Engine ECU programming device for the 35i/35iS.
Stage 1 alone will increase the power of the 35i to approximately 360bhp, whilst Stage 2+FMIC will give 400bhp+.
Once a map is installed on your zed it can then be changed to another map without uninstalling/re-installing. Note, the device can only be linked to one car at a time.
This device is currently uninstalled meaning that it can be installed on any 35i/35iS
It can read engine fault code and clear them. It will allow you to log and read real time engine data
The following maps are loaded-
- Stg1 98 RON Linear Throttle
- Stg1 98 RON Stock Throttle
- Stg1+ 98 RON Linear Throttle
- Stg1+ 98 RON Stock Throttle
- Stg2 98 RON Linear Throttle
- Stg2 98 RON Stock Throttle
- Stg2+FMIC 98 RON Linear Throttle
- Stg2+FMIC 98 RON Stock Throttle
Linear throttle is when you press the accelerator 50% you get the throttle opening 50%, with stock throttle if you press 50% you may get 80% throttle opening.
£260 delivered
I can't believe that no-one has snapped this up :o
Bang for your buck works out at less than £5 per BHP increase for just adding a remap and a very flexible remap it is. How many other remaps can you install & un-install at home and change the map from stage 1 mild remap to stage 2+FMIC for a more powerful remap.
I still have this COBB AccessPort for sale. Great flexible ECU remapping for your 35i/35iS with Stage 1 (standard engine) giving approximately 360bhp to over 400bhp for Stage 2+.
I used it on my 35i and it transforms the performance to another level surpassing the 340bhp of the 35iS. Why buy a 35iS when you can get more performance with the COBB Accessport :wink:
This allows safe home remapping of the 35iS/35i that takes less than 30mins to install and also you can then change the remap from Stage 0 to Stage 1 or Stage 2, etc in 10 minutes once the AccessPort is installed on the ECU.
Also has Read & Clear ECU faults capability and Engine real time monitoring.
Give yourself an early Christmas present :D
