clutch and flywheel kit for E85 3.0i 2003
kristian663
 Odiham
Selling my UUC Motorwerks lightweight flywheel and clutch kit due to no longer needing it. fits : E46 330i/Ci 6-speed, Z4 3.0, and '03+ 530i.
Looking for £700 for the kit.
Consisting of
Stage 2 aluminium flywheel
pressure plate '94-'99 E36 M3 pressure plate
clutch disk - UUC "Performance organic" - street use, light track use
release bearing
alignment tool
This is a SMF and non-self adjusting clutch setup and as such is much easier to install. removal of the clutch delay valve is recommended. the clutch disk is a sprung hub design and should reduce gear chatter often present in cars with lightweight SMF's.
This kit is brand new and still packaged, the flywheel packaging is slightly opened to inspect the item when it was recieved.
image url upload
adult image upload
image hosting
