Now then,
I have replaced the front shocks on my 2004 e85 and after about 15 miles I got a rather loud clunking noise which doesn’t happen unless I hit a pot hole or speed bump. Once I took it over 50+ the noise disappeared.
I have had the front wheels off and there is nothing loose at all. The only thing I have found is the screw that secures the disc brake in place has been bodged and is not holding the disc as secure as it should be, however once the wheel is torqued up, there is no movement at all. So I am at a bit of a loss as to what could be causing the noise.
Any thoughts/advice would be greatly appreciated.
GOM
GOM
