Clock setting
I have recently bought a 2003 z4 which is in a beautiful condition. I have tried changing the clock time pressed and held oil button but nothing happens. Any ideas?
Put ignition ON without starting AND make sure the on board computer display the clock and not one of the other things such are fuel consumption and the like so you should see --:-- or maybe xx:xx if there is a time registered but it is wrong. From there just long press the clock/oil button and it should let you edit the time :thumbsup:
Yep. Press the mode button on the end of the indicators and find the —:— symbol. Then press and hold the clock symbol button between the two cluster clocks, then use the button next to it (SR?) to select the numbers you want for time.
