Clicking Reversing Sensors
Player 1
Cornwall
So, every time I select reverse all I get from the reversing sensors is a constant beeping. Not one long beep and then nothing, just a constant beep that lasts as long as I'm in reverse as if it constantly thinks I'm hitting something.
I've checked the sensors to see if they click, with the ignition on and in reverse all of the sensors are constantly clicking regardless of whether you put your finger on them or not, to me it seems a bit of a coincidence that all the sensors should fail in exactly the same way all at once so does anyone know of anything else that might be causing this?
Any help would be much appreciated! :)
Sounds like the control unit/box may be faulty. Not sure where its located but disconnecting it for a while may get the sensors working. You could also try cleaning all sensors. That worked for me.
