Did a discs and pads change (used Black Diamond for both pads and discs - Predator pads and drilled & slotted discs) on the Coupe a few weeks ago. They've definitely had time and miles to bed them in by now, and are very effective, so am perfectly happy with them in that sense.
Unfortunately, under 'medium' braking, the rear brakes make a clicking sound. It's approximately once per revolution of the disk, so slows with road speed. It's most noticeable below 30 mph - due to less tyre/engine noise, plus generally 30 mph means buildings for the noise to reverberate from, but it does also do it at higher speeds.
I do not feel anything untoward in the pedal or the steering wheel, which suggests it's not warped discs or anything out of alignment.
I've tried the following:
Any ideas?
- I put new anti rattle clips on the rear, and checked the pad fit again which seems ok. I did notice the pad 'ears' don't appear to completely fill the gap between the carrier and caliper, but thought any noise from this would be a single noise per brake action, not repeating
- I've tried the hard stop to remove pad material process, but it doesn't make any difference
- I also bled the brakes at the time of fitting, though might do it again to see if it helps
Any ideas?
