Click sound on rear suspension
mcbutler
Plymouth
Hi all,
I keep my car in a secure lockup at the end of a cobbled cul de sac which has a very uneven surface. The past few times I have got the car out I noticed a click or clacking sound from what appears to be the nearside rear suspension. I have the fancy dampers fitted but no leaks there.
I am guessing bushes or similar, anyone else come across this?
Car has under 30k miles!
mcbutler said:
Hi all,
No but broken spring?
Sounds like a broken spring to me. May be that the spring has become unseated as they need to be turned to the correct angle to seat properly.
I know this may sound silly, but have you checked the roof? I recently had the same noise from mine. Had it up on a friends lift and checked all rear suspension, nothing was found. Once the roof had been up and down a few times, the noise has disappeared.
Pbondar said:
mcbutler said:
Hi all,
Good one, I will have a look tomorrow.
Hi,
It does it with the roof up or down
Spring, gone through two sets on mine and think another one has gone as well. Sound is right behind your head it seems
