The Check Control warning light appeared on the instrument cluster of my e89. Carly identified the problem was with the Footwell Module, Fault Code 009CD4 - Distrubed communication with driver's side seat belt handover. Unfortunately, Carly is unable to clear the fault.
Replacing and recoding the footwell module will be a relatively expensive repair. I'm wondering if there are any other things that could cause the fault code that I should check before committing to replacing the footwell module?
