Charge through cigarette lighter?
inkey$
Sevenoaks & Suffolk
Okay, I would prefer to trickle charge the Zed through my cigarette lighter for convenience.
My question is simply, can I do this on my ///M if I buy the charger adapter?
My 2007 ///M stays hot all the time. I know some have said it turns off after a period of time but mine does not and I do use my BMW charges via that connection. However, I also installed a direct connection to the battery in the trunk/boot and that works really good as well.
Thanks Bill. Looking at convenience connectors for the rear too as it happens. Plugging direct into the cigarette lighter would be preferable if it charged.
Mine (2003) turns off after awhile, but don't know if all M's stay on. Ask your dealer about yours, they sold me the battery terminal connector type because of this. BTW, love my BMW OEM charger!
Good advice and I'll check it out.
Okay, I'm stupidly scared of going near any car battery and have just been outside to see if I could be brave enough to hook up a battery conditioner. Anybody advise which part I need to attach for the positive? There are lots of heavy wires attached and what look like two terminal boxes, one of which is at the back and really difficult to get to (top right if picture).
inkey$, I think you should be going under the bonnet and using the terminals there instead. I think, not certain.
That's where I've got mine hooked up, very easy and "safe". The positive is near the middle of the firewall, under a red plastic cover. The ground is a large bolt welded to one of the strut towers.
You can channel the cable in the space where the pointy tips of the fender and front fascia meet, enabling you to close the bonnet completely :thumbsup:
Taz x said:
why is that more covenient?
More convenient I don't blow my face off :(
Okay, just too a look under the bonnet and negative bodywork nut is there but can't see a positive terminal or red plastic cover.
Cheers Wondermike; that pvr picture helped a lot. Found it hidden and sans plastic cover. She's all plugged in and running on maintenance mode :)
I just tried my new charger/conditioner using the cigarette lighter adapter and it didn't work, so the lighter socket in my 2007 MC isn't live all the time.
Went under the bonnet as above and all is good :)
Good to know for certain Sutts. Thanks for updating this thread as well as your own mate. Hopefully help future questions.
