Changing the leather door insert?
frazell
Hi all,
Has anyone ever removed the leather door insert on the door card? I need to swap mine over to a new door card. Had a look and it seems pretty well secured on.
Anyone with any experience of changing the leather in their car know how I can remove it and swap it over?
:thumbsup:
CJ10Jeeper has done this, IIRC he more or less chiseled it off and then glued back on after he had them dyed.
Spot on SR. Did it years ago when I wanted to change the cards to red leather. Had to cold chisel about 2 metres of plastic weld off the inside of each and then once done rebond them on. Took simply ages.
Later replaced with near new oem doorcards purchased off a forumite.
Would never attempt that job again.
Thanks all for the info.
Basically i have a small crack in the arm rest on the door so you can see the foam inside. I have found a replacement door card but the leather is a different colour.
So yeah, it wouldn't be a simple job would it!? Just want to swap the leather inserts over not spend my life with a chisel prising them off the old door and then the new one.
markeg said:
How about recolouring them - furniture clinic website has kits here
Sent from my iPad using Tapatalk HD
My experience of recolouring was not good. The look and texture never truly matched the red ///M seats. I was lucky to find a set of good OEM to swap across.
