Changing rear light bulbs - OMG !
simnew
I desperately need your help.
Bought an LED kit with a view to changing the rear reversing lights and thought I would see how the fittings come out of the rear lenses. They seemed to be pull out - great - no problem…..
Except that when I pulled the fitting out, the wiring connections became detached from the bulb holder….
There are what look like little spade connectors but I could see exactly how they were connected although it looks like the slide into the two connections at 6 and 12 o clock on tge bulb holder. The obvious solution is to pull another bulb and see how that is done, but I’m terrified that the wires will detach like the first one.
Has anyone done this successfully and reattached the sprung spades from the black and red wires back into the bulb holder?
I was trying for over an hour with small pliers but there is so little room I have come to the conclusion I may have to take off the rear light lens fitting in its entirety in order to have the access required.
Would be really grateful for anyone’s experience with this. Thanks everyone. Never had a car where changing bulbs could be so challenging….
Typical problem..maybe somebody ham fisted has been in there before…
Easiest solution is to buy a damaged unit and then cannibalise the connectors…well that’s what I did.. :tumbleweed: :thumbsup:
Think I might cut and solder the spades back into position then join the wires back together with some wire crimps. New lights only 18 months old from Magneto Marelli and I think I was just unlucky…. It’s quite thin wire. Anyone git a favourite supplier for this thin automotive wire ?
Good luck with that..as I said simply transfer bulb mounts from another otherwise useless second hand part..
