Changing from run flats
Tomsdad
A few questions
1. Can I change to normal tyres on just the front axle first?
2. What tyres do people recommend?
3. What tyre inflation kit do we think is good? Presumably I need a little compressor and the tube of paste?
Hi Tomsdad,
1. Not sure. Think new rubber is best on the rear first to prevent oversteer. In any case, when I changed to non RFT it made a big difference to the ride, so I’d recommend doing all 4, if possible.
2. I went for Goodyear Eagle F1 XL assymetric. Would recommend. Not tried many other brands yet though, so hopefully others with more experience will add. Mr Wilks...?!
3. I have 2 cans of Holts tyre weld & electric pump in the boot. Apparently it can be washed & and the wheel reused if a repair is suitable. Never used it... yet. Would be happier with a space saver E46 17” wheel & jack if I could find a good deal, and was planning a long trip. Don’t get a smaller, cheaper space saver as it won’t clear your brakes.
What about this, reviews seem good:
Airman ResQ TireRepair 71-051-011 Tyre Repair Kit https://www.amazon.co.uk/dp/B00BP5E7KI/ref=cm_sw_r_cp_api_ulEzBb4612C64
Ive never had a issue running a mixed axle set of tyres but some say its not to be done ( if you simply drive your car everday use at road speeds i really can't imagine any problem )
What i would consider is changing your rear tyre size to 245 40 18 (if on oe 8j / 8.5j wheels )
As for brands it depends on what you ask of the car & budget , there are so many decent tyres out there ,
Id consider ( in price order)
Kumho
Uniroyal RS3
Vredestein
Continental
Michelin i can't see any disappointment in any of the choices ( for 99% of forum owners :wink: )
For punctures buy a decent gunk kit with inflator like the Continental often supplied free with a lot of new cars https://www.ebay.co.uk/itm/HONDA-CONTINENTAL-ALL-MODELS-TYRE-PUNCTURE-REPAIR-KIT-PUMP-COMPRESSOR-HKIT2/142838104356?hash=item2141d08124:g:TIEAAOSwhBxbKNbS
