monkadill Senior member Jun 22, 2013 #1 Hi, is there a certain dimension BMW centre cap that i need for my BBS 18inch wheels. The 17 inch BMW centre caps did not fit? Thanks, MArk
Z Z4M-2006 Elite High Peak,Derbyshire. Jun 22, 2013 #3 I have a set of BBS caps at work.. Think they are 65mm....
Z Z4M-2006 Elite High Peak,Derbyshire. Jun 22, 2013 #5 I didnt..... They were off a set of wheels i had....
monkadill Senior member Jun 22, 2013 #6 oh, ok. I need to know what size diameter BMW centre caps i need for my BBS wheels and to replace the BBS caps. The outer dimension is 70mm.
Z Z4M-2006 Elite High Peak,Derbyshire. Jun 22, 2013 #7 Ahhh.. So you want to put BMW roundels on BBS alloys? What BBS alloys are they ?
monkadill Senior member Jun 22, 2013 #10 ha ha - nope - BBS centres, i wanna put BMW centre caps on them
monkadill Senior member Jun 22, 2013 #12 I did measure the caps externally and they are 70mm. Wanted to ask before taking the wheels off though.
M Marius Senior member west sussex Jun 22, 2013 #13 monkadill said: I did measure the caps externally and they are 70mm. Wanted to ask before taking the wheels off though. Click to expand... if yours 70mm, most likely you need 70mm ,unless you want to try your like ant try to fit 56mm :lol: :lol: :lol:
monkadill Senior member Jun 22, 2013 #15 My OEM caps off my 17's didn't fit the BBS CK 18's and i assume they are a standard size. I can't check there size as they were sold with the wheels.
Z Z4M-2006 Elite High Peak,Derbyshire. Jun 22, 2013 #16 My BBS ones are definatly 65mm... Just measured them.
R RichD Member Leicestershire Jun 22, 2013 #18 If you have the 108 bbs split rims i think they are 68mm. These are the ones i've just fitted. They're not oem but good quality. http://www.ebay.co.uk/itm/281118817865
