Centre cap size for 108's?
tek81
I'm wanting to replace the centre caps on my z4, can anyone tell me what size I need to buy? I've seen them ranging from 60mm-68mm.
Cheers.
Cheers.
The caps on my 107s are definintely 68mm. I don't think BMW will have used a different size on the 108s. :?
can confirm they are 68mm on the 108s.
bear in mind 3rd party caps don't always fit "perfectly".. hard to explain until you've seen it.
my prefered solution to this is a little bit of electricians tape around the inner area of the wheels where the caps clip into.. solves the problem perfectly.
I just brought some caps from ebay that were advertised as 70mm (after previously buying some 68mm ones which fell out :roll: ) and they fit as good as the originals. Ok the badges are not as good quality but they are miles better than the ones I had on.
These are the ones:
http://www.ebay.co.uk/itm/151315577857
However I have just checked and they are no longer available :roll: so not really that helpfull I suppose :D
Chris
